This green/yellow tint and black crush happened after a month of use. I Sent the phone to service /repair and they changed components and upgraded to Android 10. Everything was great, but now after about 2 - 3 weeks of use, the same effect have started to appear again. Is this the general issue with oled displays?
Can anyone see the pictures?
Hi @Kurre ;
The pictures will only be visible after moderators/support staff approve them.
Regarding the issue you are facing and describing it shouldn't be normal in oled screens, but I can tell you that I already returned two Xperia 1 because it happened to them the same thing you are describing and I don't know what caused it, so definitely I think something is not right.
hello,
i ve bought an xperia 5 recently, and received it 2 days ago.
i think i m experiencing the same green/yellow tint as seen on your photos.
i would never believe that my old xperia xz2 ips screen would have darker black than xperias 5 oled screen.
on every video i was watching that had dark colours i was seeing this greenish tint and even tried to put side by side the xz2 with the xperia 5 to compare ... then i saw your post.
so is my screen faulty? is this common for all oleds? thanks in advance,
where did you go from there? did you contact sony support?
let me post my pictures
Stop cribbing here.... Nobody is going to help you here in this forum.
Sony support is equally useless, your best bet would be to return the phone
Yellow/green tint is normal for OLEDS 🤷🏻♂️🤷🏻♂️🤷🏻♂️ but on Samsung or iPhone OLEDS it's less visible. Because they have better panels. Anyway I was so disappointed when I got OLED phone and I think LCDs are much better. OLED screen also change their colours depending of screen brightness... So you must deal with that.
But the pictures from first post is saying that you need to take it to service. I can't see the new photos @erase
they prolly need to be seen/approved by a moderator..
are the forums being moderated during weekends?
can you see the pictures now?
Hi. Now I can see them, looks like the same issue as for my Xperia 5. Have sent my unit for service repair a second time.
Yup you should send it to service
