How to preview action cam's input into pc
scottkane
Hi guys,
I have sony hdr as50
I have the playmemories app for smart phone that shows you what it records and all, but how do you do this on a pc? win7 no wifi only lan
Thank you so much!
IamNic
That is not possible without extra accessories.
For the AS50 you would need this cable https://www.sony.co.uk/electronics/video-cables/vmc-15fs and a component video grabber like this: https://www.amazon.co.uk/LogiLink-USB-Video-Adapter-Audio/dp/B0013BXFLG/ref=sr_1_3?ie=UTF8&qid=15030...
I though recommend this one: http://www.magix.com/gb/rescue-your-videotapes/ since it already comes with software, which can also record.
You will only get a 576i video preview with this method anyways.
- Nic
