Hello Everyone,
I just got a new a6300L (with the KIT lens - SELP1650 OSS), and I found that at wide focal length (16-18mm) the autofocus is really slow at aperature of f11-f22. Is it a normal operation, or should I take it to a service point?
There are no problem at any other focal length or aperature, it focuses very fast.
Thanks for the help in advance!
Gy
Hi gyszeifert,
Welcome to the community.
I'll see if I can find anything out for you - someone else in the community may be able to assist in the meantime.
Thanks,
Pascale
Hi gyszeifert,
I'm not quite sure whether this is normal or not. Does this happen when you use any other lens?
Cheers,
The_Black_Rose
