Hi
I just bought a A6300 with a 16/70 lens. Works super - without the memory card... but since the memory card is important, how can i then solve the same problem wich is coming back everytime I´m trying to take a photo?
Step 1: I take the photo - then Im told "Recovering Data" - "Please wait..."
Step 2: The camera is behaving like it restarts, due to the SD card problem.
Step 3: I´ll then get the message: "Writing to the memory card was not completed correctly" "Recover data?"
I can not do anything else, than press "Enter" And then I´m getting a message about executing and that will damage data, wich I ofcourse have to accept, otherwise I wont get out of "the circle of cancel or execute"
The camera is working super, as I said, without the card.
The card is a SD XC 128 GB Deolux.
The question is asked here, since I saw that other people have had the same problem - with other cards, the most of them having no succes by changing card/format it.
And i tryed format it - wont let me, neither from a computer.
Can anyone help me here?
Thanks in advance and sorry for my english
Best Regards
Anders
Solved! Go to Solution.
Follow up to my issue above.
I went to a store to try my memory card in a similar camera. The same problem showed up.
The short solution was then to buy a new card - this from SanDisk, since they didn´t have Sony SD Card..
The result was a functional camera 🙂
So, to others (what I didn´t know) Buy SD Card which are able to write in a proper speed.
(Ofcourse it wasn´t Sony) 🙂
Best regards
Anders
Happy camper
Best regards
Anders
Happy camper
@B41813 Hi and welcome to the Community
Thanks for posting your solution to the pronlem, it may well help somebody else
I have also had a problem with a Sony SD card that will only let you view images if it is in a camera, but when inserted direct into the pc it doesn't exist 😞
