Asked the sony center, said there is no warranty for cleaning and it's not a defect.
I am interested, how much will affect the pictures? Thanks
Solved! Go to Solution.
Hi anatolymar
Assuming this is a particle like a dust speck, it shouldn't affect the image at all.
You're much more likely to have a dust particle on the sensor visible in finished photos than one on the lens; in fact most sensors have near-invisible dust specks on them at any given time which are still way more obvious than visible particles on the lens.
Mick
Hi anatolymar
Mick
