How to get firmware apps onto a6300...seems complicated...just like all sony site??
iprior
12 REPLIES 12
jumpsuit
Hi @iprior
I have just managed to sign in fine using my account details from here.
What error message are you getting?
iprior
I can sign in to the site, but am asked to sign in again when trying to get apps. then justs tells me I have not used correct sign in info?
ps this is not solved.
jumpsuit
Hi again
I think its probably best you contact support as I have had no problems
with the site.
Give them a ring on +44 (0) 2073652810
(They close at 18:00 though)
The post has been marked as solved as you successfully managed to update your firmware after being
directed.
