How to get firmware apps onto a6300...seems complicated...just like all sony site??
iprior
jumpsuit
Hi @iprior :slight_smile:
Have a look Here for a guide on how to install apps.
If you want to update the firmware have a look
Here for the latest update for your camera and how to install it.
12 REPLIES 12
jumpsuit
iprior
Thanks...seem to have done everything ok...now have VER 2.1 but cant find anything in "Applications" on canera? Just 3 boxes..App management/ smartphone / playmemories. if I open app management  3 options  Box / manage ane remove /display account    if i open sort..more boxes???
iprior
ps..cant see anything onpc?
jumpsuit
Hi again
What apps did you have on the a6300?
iprior
New camera...apps tab empty...have tried to d/l as you showed ,but althought I now hav ver 2.1   cant see any apps?
iprior
It has just occured to me that if I now have Ver. 2.1   this does not give me the apps to d/l but , that i now have the ability to access site to do so..??   if so, where is this?  thanks
jumpsuit
Hi again
As the camera is new it doesn't sound like you've got any apps yet
so they won't just appear on the camera.
Please check  the first link I posted above, it shows you to go to:
https://www.playmemoriescameraapps.com/portal/
where you can connect your camera and purchase / download some apps.
iprior
I have been there..will not accept my sign in details!   very Sony!  do I have to set up separate password etc for this?
iprior
I give up...this is the very worst site ever!  I can sign on here but not on the app page?   thanks anyway.
