HVL-F45RM software update
Schnauzervillage
Just been notified of the latest software update for HVL-F45RM, Updated my camera (A7r3) OK. But Flash uses a multi micro USB and when connected to my PC or MAC it is not recognised. Tried different cables - no luck, Anyone else got same issues?
Regards PJ
Schnauzervillage
Problem solved! - tried a 3rd cable from my flash drive seems to have worked ok on my MAC.
Schnauzervillage
