Play memories auto-launch...
manbitescat
Anyone know how to stop Playmemories auto-launching every time I plug the camera in? Driving me nuts (Mac OS X)
IamNic
Hi @manbitescat,
you can deactivate the auto-launch in the settings.
It is the first tickbox under the option "import" in the programs settings.
- Nic
manbitescat
Unfortunately '..you can deactivate the auto-launch in the settings. It is the first tickbox under the option "import" in the programs settings...'
This is not the solution. I unchecked this box as my first port of call. The application still auto-launches every time the camera is connected via USB.
Solution: Go to
/Library/Application Support/Sony Application Launcher/USBProductNameList.plist
Change name to /Library/Application Support/Sony Application Launcher/*USBProductNameList.plist
App will not auto-launch, but will launch on request (manually).
