can you use playmemories to play back video?
Badmonk
hey guys
just started using playmemories with my A7S2, and got it connected via my ipad. it works fine as a second monitor and for playing back still images but can it also play back video please or is this feature not supported?
thanks for any help
Jonnie1266
Hi @Badmonk
Yes you can :smile:
PlayMemories allows one to upload video from camera / camcorder memory then edit and either store to hard drive or burn to disc. Depending on the processor speed the video will play back with or without 'stutter'.
I should perhaps mention that I use Windows 7 but I am sure that Apple iOS systems allow for editing and playback. I do not think however that burning to disc is supported due to a decision made by Apple several years ago regarding optical drives. There is a way around this if you require that facility but not using PlayMemories.
Regards
If it ain't broke don't fix it
