PlayMemories Star
stevef2
PlayMemories Star
Can anyone tell me what the asterix/8 point star means in images within PlayMemories.
Many Thanks, Steve
profile.country.de_DE.title
cmosse
That icon you are referring to is “Photo with GPS location information”. The camera you are using has a GPS Geo-Tag that would inbed latitude and longitude calculations that can be displayed when selecting “Open With” on the menu bar of the PMB software. You would then select “Map View”. Google Maps will then open and display the location where the photo was taken. This information is also located in the PMB Help window.
cmosse
