Problem installing apps on a sony a6000
Yannis20
I can operate correctly the preinstalled remote control app, which means that all settings for network a d wifi are OK.
when I try to install a new app, it gives me an error message that the server is unavailable. I believe that the predefined http address is  not valid anymore, but do not know how to change it.
does any one have a similar experience and a solution to the issue.
regards
Yannis
Hi Yannis,
Have you tried a factory reset?
Best wishes,
M
Yannis20
Thanks for your response. The problem is solved. It was due to the fact that Sony has many websites and you need an account in each or you need to sync accounts to each one.
It would be nice if Sony either references the issue or syncs accounts automatically with a notice to the user.
