Where is the "PC Remote" function on the Sony NEX 6 (V 1.03)?
ManuBaires
Hi, In order to do remote (tethered) shooting with the the Sony Remote/Viewer/Edit Software, I have to turn on the PC Remote Option at my camera under MENU/USB Connection. But therre is no such option. The Firmware is ther latest one (1.03) and the camera is connected to my computer by a regular USB Cable. I only have the options Auto/Mass Starage/and MTP and non of those works. The Software is meant to work with a Nex6 but the camera don't connect.
Did someone solve the problem?
Pascale_F
Moderator
Hi Manu,
Welcome to the community.
I will pass your message on to the team and someone will update you further.
Many thanks,
Pascale_F
Janrap
Any update on this? been tryng to find the PC REMOTE from the camera settings.
