Sony alpha 200 camera error
Colinley
Hi I was recently given an alpha200 but it had no battery or charger. So I bought a battery and charger off ebay. When they arrived I put a cf card in the memory card slot but when I put the battery in there was a clicking noise that lasted for about 3 seconds coming from inside of the camera. When I turned it on the same noise happened again and it said set time and date for about one second on the lcd screen and then it said camera error. I turned it off and took off the lens. Took the battery out then put the battery back in but with the lens off. It made the same noise and I noticed it was the mirror flicking up and down. When I turned it on it did the same again. Mirror flicks up and down quickly for about 3 seconds. Does anyone havery any ideas what it is doing this. Any help is much appreciated
Thanks Colin
EdwinaU
Moderator
Hi Colinley,
Thanks for joining the community.
It might be best to contact support for advice about this as it seems like a mechanical error.
You'll find the contact info here.
Best wishes,
EdwinaU
Colinley
Thank you very much for the reply. I have sent the details to support and I an awaiting a reply. But with it being an older model I have heard that repairs can be very expensive. And I feel as though it might not be economical to have it repaired. Unless I can find a way to fix it myself
Colinley
So I got a reply from sony. They asked me to check that the battery is suitable for the camera. The one I got was off ebay. Not a genuine sony camera but a compatible one. It had good reviews with other customers not reporting any problems so I think it is going to need a repair. But if it's going to cost more than £100 it won't be worth it because I could buy another one for around that price that is working
