Is anybody else haveing an issue with this lens ? I have found it will not focus in AFS or Manual - only in AFC when used with my A7R2. I have Version 4 firmwareloaded. It front focuses by quite a large amount.
Solved! Go to Solution.
I have been asked by Sony UK to send both lens and A7R2 camera back to the Service Centre - I am awaiting a reply.
Hi Burg,
Welcome to the community. I'd suggest you get in touch with support for advice, you'll find their info here.
Best wishes,
EdwinaU
Thanks I have contacted Sony Suppoprt.
