100hertz Sony TV 55 “
pecartl30
My new Sony is supposed to be 100-400 hertz but where the plug socket goes into the tele it says 50Hertz and the picture is good but nothing like it was in store. Have I received a different tv
royabrown2
Hero
@pecartl30 wrote:
I WAS TOLD THAT I HAD PURCHASED A 400 HERTZ TV.SONY BRAVIA KD-55XF759 6  HOWEVER THE DOCUMENTS TELL ME AT FULL RESOLUTION 4096 X 2160P  ITS ONLY 50-60HERTZ . IT DOES HAVE SONY MOTIONFLOW. HAVE I BEEN DUPED OR IS THIS TV INDEED 400 HERTZ. THERE IS NOTHING EITHER IN DOCUMENTATION OR PACKAGING TO CONFIRM BUT THE ONLY REFERENCE IS TO THE POWER PLUG AT 50-60 HRTZ AND THEN WHAT I HAVE SHOWN ABOVE. CAN ANYONE HELP? THANKS
400Hz mains is sadly unavailable in the UK, or even in the US, so Sony are unavoidably restricted to the 50Hz AC coming out of the mains in the UK, and 60Hz elsewhere. But worse, the power comes out of the brick at 0Hz (DC).
However, here is the spec for this TV, which quotes:-
MOTION ENHANCER      Motionflow™ XR
(NATIVE HZ)                     400Hz (Native 50Hz)
So there’s your 400Hz, right there, and the native 50Hz it looks like the panel actually runs at.
i.e. It looks like he gave you both numbers, correctly.
But I don’t know where you got that 100Hz for the panel from......
16 REPLIES 16
Marino.Manolo
Genius
Are you confusing the Hz of the current with the Hz of the image? (Panel)
It is always better to enter the TV model when you ask.
Manolo
LightFoot
Specialist
This has got to be a wind up :slight_smile:  The Picture you see in store is a special retail demo mode not recommended for home use. The 100-400 hertz is Motionflow and nothing to do with mains electricity.
royabrown2
Hero
It’s very probably an entirely genuine question.
The real wind-up here is Motionflow - the software interpolation that varies from 400Hz clean up to 1000Hz, depending on the spec level of the TV, despite all the panels being at most 100Hz panels.
And I defy anyone to tell, with or without instruments, whether a given Sony TV is giving the claimed Motionflow rate or not. (There was a set a few years ago where the silver bezel version was claiming a different rate from the black bezel version. And Sony insisted this was the case. Yeah right. Unless which colour bezel you have affects the picture quality, maybe? ) :yum:
But yes on the other count, the demo settings these TVs are on in the shop is cranked up to eleven. @pecartl30 can find this Mode if he pokes about in the menus, and can satisfy himself that the set can do this. But the cartoon-like primary colours will soon pall, I think.
IamNic
Also on a side note - the AC is converted to DC in almost any electronic device, so internally these devices can play around with frequencies as they please. Otherwise there wouldn't be any 144Hz PC-screens or flicker-free studio lights.
- Nic
pecartl30
Thank you for your help the tv is KD55xF7596.
i researched before I bought and the Sony site appears to say all “New” tv’s have freeview built in but previous models did not and you needed either a digital box or Ariel , however newer TVs should have it built in so no need for these. Is mine an older TV because it is not built in and I have no Ariel and no digital box . The previous tv had it built in.
LightFoot
Specialist
Hi @pecartl30   To receive Digital Terrestrial channels (Freeview) you need to plug in an TV Aerial or Cable into your KD-55XF7596. Your TV also comes with a Satellite Digital channels (not Freesat) in which case you need to connect your satellite dish to your TV. Make sure you choose the right type and connection to tune in the right channels.
royabrown2
Hero
Can we please all be a bit more precise about the term ‘Freesat’? This refers to a particular licensed EPG, with assigned channel numbers and full forward programme details for 7 days, and this isn’t present on these Sony sets.
They do indeed have a satellite tuner, but it doesn’t use the Freesat channel numbers, and only comes with Now & Next by way of an EPG. And many of the channels aren’t free anyway.
Retailers of these Sony TVs are careful to avoid using the term ‘Freesat’, or even of letting potential buyers use it uncorrected - and those that weren’t, initially, had to accept returns over this.
And we must take similar care when posting on the Community to avoid any :broken_heart::slight_smile:
LightFoot
Specialist
Hi @royabrown2   Thanks for pointing out my ignorance.
pecartl30
