49X8000 restarts when wifi connect/disconnect
Morihonest
I have a 49X8000 which restarts when wifi connect/disconnect.
Scenario A:
1. Turn the tv on
2. Connect to wifi network
3. Disconnect wifi network
4. Connect again
5. Tv restarts itself
Scenario B:
1. Turn tv on
2. Connect to wifi
3. Press power to go to standby
4. Press power again to start tv
5. A few seconds later it restarts itself (maybe because it connects to the wifi)
Notes:
1. My tv language is set to Persian(Farsi).
2. I tried updating the firmware and I am using latest version.
3. I tried factory reset and same issue exists.
profile.country.AT.title
Kuschelmonschter
Hero
This bug has been existing for 5 years already, see here. Don't expect it to get fixed.
6 REPLIES 6
Sean_Mc
Moderator
Hi there,
I would recommend getting in touch with the Sony Support team here for further help.
Best wishes,
Sean
Kuschelmonschter
Hero
Do you use VPN?
Morihonest
Yes. Is it a bad idea or something?
Kuschelmonschter
Hero
Morihonest
Thanks for your reply.
It is a shame if it is not fixed yet by Sony dev team
Morihonest
Betreff: 49X8000 restarts when wifi connect/disconnect
I developed an app which solves the problem by disconnecting any vpn when screen turns off by power button. So when screen turns on, device does not restart!
Anybody can download it from https://github.com/Morteza-Rastgoo/Sony-Android-TV-VPN-Crash-Fixer/releases/tag/V1.0
This app is open source. You can find the source code here: https://github.com/Morteza-Rastgoo/Sony-Android-TV-VPN-Crash-Fixer
UPDATE:
I developed Shadowsocks client app for android to do the same job plus:
This app disconnects any vpn on device when screen turns off, to prevent the bug on some devices when Screen is turned off and VPN is On, when device turns on, device restarts itself. It turns on vpn again when screen is on.
Also pressing Green Button on remote control Turns vpn ON and pressing Red Button on remote control Turns vpn OFF
available on https://github.com/Morteza-Rastgoo/shadowsocks-android/releases/tag/AndroidTV
