49XD8305 and IPv6
mikesmith63
49XD8305 and IPv6
having got my tv communicating without failure over Ethernet, I decided it was time to look at the other setup options.  So naturally I tried the prioritising IPv6 setting but i haven't been able to make it connect.  I can get it working on the LAN but it fails on the WAN, has anyone been successful over IPv6 yet?  I do have real IPv6 connection to the outside world on my router and am using googles IPv6 dns.
thanks, Mike.
mikesmith63
My bad, I had slaac stateless management when I should have had dhcpv6 stateful selected. Now works seamlessly with IPv6 as the priority.
royabrown
Enthusiast
@mikesmith63 wrote:
thanks, Mike.
I just turned IPv6 on, on my KD-43X8309C, and it connected, and is communicating fine.
But setting IPv6 does not seem to make IPv4 go away, so maybe it is still using this?
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
mikesmith63
