My newly bought TV restarts everytime I try to search for digital channels (or analog channels).
Also restarts when trying to tune manually.
I managed to get the channel search working one time, but everytime the tv starts and jumps to tv "mode" it restarts again.
Is this a software related problem and can I fix it myself? The TV downloaded and installed the latest software when I first made my setup on the tv.
Can that be the problem? Can I reverse the latest software?
Hi there
What a weird and frustrating problem you have!
At the moment, I can only suggest that you do a factory reset of the TV, instructions HERE. Also check the condition of your aerial cable and that it is plugged in fully and in the right socket.
Edit: There is no way to roll-back the firmware. But a factory reset after a FW update can work wonders.
Thanks for your reply!
I tried a soft reset without sucess, everytime I try to search for channels the tv restarts itself.
Unplugged the CA modul and the antenna cable and made a channel search just to se what happend.. Same result, tv restart itself. Everything else seems to work... very frustrating.
Think I´ll have to return the tv and have it checked 😞
I had same problem on my kd75xd8505 it had been tuned to yourkshire by the online shop i live in teeside so clear all stored chanells and retune it worked for me
