Adding a Blu-Ray Player to Android TV
exaliesha
I want to add a Blu-Ray player to my Sony 43xe7003bu TV bought in January 2018 and working with a Sony HT-SD35 Sound Bar and sub-Woofer.Any advice on best model not too expensive!)and connection issues would be welcome.
exAliesha
2 ACCEPTED SOLUTIONS
royabrown2
Hero
@exaliesha
Stay all-Sony; there shouldn’t be any issues at all. Plug in via HDMI and off you go.
HD or UHD?
https://www.sony.co.uk/electronics/blu-ray-dvd-players/t/blu-ray-disc-players
For HD, pick the BDP-S3700: the 1700 isn’t WiFi, and the 6700 would let your Sony TV upscale anyway, so the upscaling would be wasted; £79 at Argos
For UHD, if that is what you want to really do the TV justice, the UBP X700; well worth the small premium over the X500, and I doubt you will want to go up to the X800. £184 at PRC Direct
Tonycv51
I don't think your TV has dolby vision so I'd maybe think about the x500 and save £60 (assuming you want 4k Blu Ray)
5 REPLIES 5
royabrown2
Hero
@exaliesha
HD or UHD?
exaliesha
Many thanks, I'll check the models you listed.
exAliesha
Tonycv51
Tonycv51
Actually one thought.  Would you ever want to play a CD to your soundbar with the Tv switched off? In which case go for the x700 and not the 500 as you can output via digital to your soundbar (though looks like you'd need a converter as ones optical and ones digital)
4k player needs connecting to hdmi 2 assuming you use the arc connection to your soundbar
exaliesha
Many thanks, I'll check out both the 500 and the 700.
exAliesha
