KD-49XG8396 - wifi problems
maxi20
Hi everyone, got a problem with above TV that seems to get a lot of attention. I bought the first one in April and after a system update started to get a message saying wifi not connected every 30 mins followed shortly after by another message saying wifi is connected. Was advised by Sony to use USB stick and upgrade to software version 6.6555 which I did but the problem continued. Was then advise to do a factory reset but the problem still continued.
As the TV was less than 30 days old, arranged for a replacement which arrived and had software version 6.6050 installed. I had no problems with this wifi on this TV.
Today the TV upgraded to software version 6.6555 and the wifi problem returned. Sony say the 6.6555 version was  "Regarding your enquiry for your Sony TV, kindly note that Software Version 6.6555 was released to solve the Wi-Fi issue and other Software related issues."
Really stuck with problem now as I don't know if it is possible to reverse this update and return to 6.6050.
Anybody got any ideas please.
8 REPLIES 8
Hi there,
It would be best to contact Sony support here.
Let us know how it goes.
Best wishes,
M
maxi20
Many thanks for your reply.
Was in touch with Sony support today, spent about an hour on the phone with them, they then took remote control of the tv,  (didn't know they could do that), but nothing resolved. They said they would take the problem up to the next level.  Don't understand that either  but they said someone will contact me within 48 hrs. Will just have to wait and see what happens.
Got rid of the messages by turning off  the tv wifi but now instead of a SMART tv I now have a DUMB tv.
maxi20
Well, the 48 hrs when they said they would reply by has long gone and nothing heard.
Contacted Sony Support and asked if any news but no there isn't. Enquired about the possibility of a replacement or refund and was told that the warranty only applied to "hardware" and as I had a "software" problem the warranty did not apply.
Strange that it was their software that caused the problem.
Not very impressed with Sony Support.
Tonycv51
Sky router?
If so you can try turning off IPV6 for lan and dhcp in the router settings, and reset up the Tv network connection
maxi20
Thanks for your reply.
Yes it is a SKY Router, tried turning off IPV6 on LAN but made no difference.
unticked box from Enable  IPv6 on LAN side and
unticked box from Enable IPv6 DHCP Server
maxi20
Also wondered if it would be worthwhile trying a Powerline Adaptor connected to the LAN socket and leaving wifi turned off at the TV.
Tonycv51
Worth a try.  There's another thread like yours and not sure if that's wired. Can you temporarily hook it up by lan cable or get some power lines with free return like amazon?
maxi20
Unfortunately too far to router to use cable, will see if anyone round here has a set of Powerlines and are willing to let me borrow.
Was really asking if anyone new if that has sorted out the problem for other people.
If it will cure the problem and I get a smart tv again the price of the Powerlines will be worth it.
