AF8: Wall-mount screws
I have bought a wall mount from Vogel for my AF8. The WL-450 was too short...
Which size/length should the four screws be that should be screwed in the TV?
thanks
Mick_D
Moderator
Hi @Kulmeddjur, welcome to the Community.
The TV needs 23mm M6 bolts, as supplied with the bracket.
Sony do recommend the WL-450 for the A8F, what was the problem mounting it?
Mick
