AF9 pop up
PaulinBont
AF9 pop up
How do I disable this
So annoying when it regularly pops up
HannahEd01
Community Team
Hey Paul, try fcookes's solution, obviously this is not an issue with the TV itself.
29 REPLIES 29
Eskimosony
PaulinBont
When I turn it off then Netflix, Prime, YouTube don’t work
Eskimosony
fcooke
Mine started doing this 2 weeks ago after I switched from Plusnet to Now broadband. No problem in previous 2 years…..
Eskimosony
fcooke
2.4 and 5 are both on by default
there is no power save function on the router….
Eskimosony
fcooke
Thanks but it doesn’t apply to the Sky/Now router and Ethernet is not an option.
Eskimosony
