AF9 pop up
PaulinBont
AF9 pop up
How do I disable this
So annoying when it regularly pops up
29 REPLIES 29
PaulinBont
Yes, same with me as well- with Sky
Eskimosony
fcooke
No, you have no idea how a Sky/Now router works.  Go and patronise somebody else.
Eskimosony
fcooke
Yeah that's right. Troll off.
Eskimosony
Just can't help some people
fcooke
I've tried the previous tips - soft and factory reset, network not broadcast time, latest firmware version, reset router etc. Seems like most people fixed issue but those with Sky/Now broadband/router haven't.   This is one you might not have tried, menu changed a bit but found in apps.
I am just going to turn wifi off when watching sky and turn on for netflix etc. Seems odd to watch a streaming service and tv says it can't connect to wifi......
Wish I hadn't switched from Plusnet....
Update Android TV Core Services application from the Google Play Store
  1. Press the [HOME] button on the remote control
  2. Select the [Apps] menu
  3. Select the [Get More App] icon
  4. Sign into your Google account
  5. Select the [My App] menu in the Google Play Store
  6. Select the [Android TV Core Services] application
  7. Select [Update]
PaulinBont
I’ve been with Sky for years and very happy with the service I’m getting but this annoying pop-up has only been regularly errrr popping-up, relatively recently
Eskimosony
HannahEd01
Community Team
Hey PaulinBont, have you tried the update for Bravia Core? Also, what's the software version?
