After turn on KDL 43W805C image is displayed but no sound and TV lock
Cyberlife
Hello
Less than a month that I've bought Sony KDL 43W805C TV
I updated TV And there was no problem, But in two previous day After connecting power and turn on the TV, image is displayed but no sound and TV could not be controlled via remote and the buttons on the TV And should pull the plug from the outlet and then connect again
How do I fix this problem
4 REPLIES 4
hextablephil68
Me too, this is getting ultra annoying now. Sony say do a factory reset.  Done this but problem still exists
profile.country.GR.title
MiCal1967
Remove batteries from both Remote Control and Touchpad Remote.
Then check if TV channels or sound can be controlled from TV buttons.
Sometimes a whichever stuck button on a remote blocks all other operations.
This could also be a stuck button on TV backside control. Check the feel of a pressed button on those. Try to "feel" the click.
Cyberlife
The problem is not the remote control and Sometimes these problems occur
How can I report this problem for providing update
MiCal1967
Did you wait for about 30 seconds before unplug the TV?
We all have this 20-30 seconds freeze but then everything is OK.
Just happens occasionaly
https://community.sony.gr/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2148608#M42563
You can also try this.
  • Uninstall all apps that you have installed on your android TV. Check through Settings -Apps. There must not be any Downloaded apps. Just System app and Running apps.
  • Disconnect and forget(delete) every Network connection on your TV.
  • Unplug every device connected via HDMI or other way.
  • Unpair any paired android or Bluetooth device(remote, keyboard etc)
  • Clear cache, if possible from all the apps by entering Settings - Apps - System app. You shall need patience since there are many many apps. It might last 30 minutes or more. You must see after clearing  every app cache a 12,00KB remains which is normal.
  • Reboot your tv by press and hold Power button for more than 5 seconds or via Settings-About.
  • When picture is On wait for about 60 seconds for every startup app to be loaded(discover etc)
  • Then execute a Factory Reset following this procedure:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/66442/kw/factory%20reset
