How can I disable sony bravia android tv keyboard
I have connectrd a USB keyboard to my tv, it works fine but everytime i'm typing the screen keyboard pops out. Is there anyway to disable the screen keyBoard?
profile.country.GR.title
MiCal1967
There are apps that do not allow this keyboard to hide, like Kodi, except if there is an option for setup.
Embedded apps should hide this automatically if an external physical keyboard is connected.
I have a 4K Sony Bravia X850C and it is really annoying the keboard apears in any search bar, I have to hide it manually everytime and I can't find any option to disable it 😞 Thanks for your reply.
