Android KD55X8509C stuck at language select
BearFowler
Im in need of some help. After trying to reset my KD55X8509C the tv is now stuck in a loop at the language / network selection screen.
Is there any solution for this? Any way to factory reset the TV from this point?
If tried to reset the tv following some information on this site by pressing the up arrow after turning the tv on but it does not appear to do anything,I think the procedure is only applicable to 2014 TVs. Can anyone confirm this?
Any help would be appreciated
Michael
22 REPLIES 22
BearFowler
update 2
TV repair guys came and took the TV away. Should be back at somepoint next week.
Michael
BearFowler
Final update,
received a call last Wednesday saying TV has been repaired. Delivered back today all sorted.
Thanks for the help to the forum guys,Quinnicus and Sony.
Michael
Hi there
Thanks for the update.  Glad its all fixed for you now :slight_smile:
