Anybody with a KD-49XF9005?
profile.country.GR.title
npapanik
Could you please check the following for me: look inside the ventilation grill on the top of the TV while it is turned ON. Can you see any lights inside? Thank you in advance.
KD-49XF9005
HT-CT390
stormyuk
Hi there,
I don't have an XF but I have the previous XE model which is very similar and can confirm I can see a green LED inside the case from the top grill. Not that I have ever looked before!
Hopefully another XF owner can confirm with you if you are still concerned.
npapanik
Many thanks for the answer! I will look into it when it returns from the service. Thanks again!
KD-49XF9005
HT-CT390
