I have just set up my tv and have about 10 standard apps. How do i get more?
Hi there
You should see in the apps list a Google Play store. This is where you can install other apps/games etc.
Hi
I thing this is region related issue
did you set up your google account? If yes, just open up a playstore. If not, do that first.
Hi @Anonymous
When Language is set in my Region there are very few.
For example there are no apps at all @ Tools & Utilities
Strange thing is that when going back to region Language some of the previous found apps remain or can be more or less!!
When Language is set to English there are:
Home
7 apps -> Featured Apps. Back to region again gives 14
6 apps -> Movies+TV. Back to region again gives 16
20 aps -> Top Paid apps
20 apps -> Top Free apps
7 apps -> Featured Games. Back to region again gives 11
16 apps -> Enteraintnment Apps
7 apps -> Music Apps
34 apps -> TV Remote Games
20 Apps @ Media Apps
20 Apps @ Music Apps. Back to region again gives 7
20 Apps @ New Apps
15 Apps @ Tools & Utilities. Back to region again gives 0 (No results found)
region or language? It's not the same. I have my region set but UI is on english just like on any other device and I have see all the apps.
Language
This could also be regional information according to your DNS servers, if not already Google's.
It is language dependant, happens also here.
Not sure how i would get to google play. This is a picture of all i have. No access to anything else. The manual is useless....
