Sony KD-49XD8305 TV
dahardy95
Sony KD-49XD8305 TV
Hi, can anyone give any advice? I have this tv which is absolutely superb, but I am having a few issues getting the colour set properly. The RED seems to be overpowering all the other colours. On standard definition it is a lot worse than Hi Def. I have turned the red gamma down, but the red colour is still too strong. Has anyone got any settings they can give?
Mooly01
The general settings I use are here (currently 4th post from the end of thread)
https://community.sony.co.uk/t5/android-tv/usb-recordings-are-jerky-when-played-back/td-p/2271707/pa...
If you have altered gamma and other advanced settings (and haven't noted down the original settings first) then I would recommend a factory reset and start again.
Mooly01
Also follow this guide and use the test chart available in the link:
https://community.sony.co.uk/t5/how-tos-faqs-tvs-home-cinema/our-definitive-guide-to-the-perfect-tv-...
