Audible clicks when changing channels
PAULJA
Hi
Ive just replaced my ageing Panasonic Plasma with a Sony 55A80L, Ive connected my home AV system (Yamaha RX-V1065) using an HDMI and the optical audio as per the previous plasma set.
With the TV set to use external speakers via the Yamaha we get 2 distinct clicks (electrical noise) when changing channel (and other remote operations). Nothing can be heard when using the internal speakers.
I’ve been through the audio output menu and changed settings to no avail
So with the same install / cables etc the Panasonic is fine and we get audible clicks from the new Sony
Any ideas ?
We are currently not using the AV system !!
11 REPLIES 11
royabrown2
Hero
@PAULJA
Don’t you mean the Sony Click Wall? 😛
rooobb
Sorry for my bad English, I meant "system sound" in the setting of your TV not eliminating the avr that is obviously not a solution .
