BBC iPLayer only in Sony select, cannot move it to apps
Kicking_up_Dust
I only want to show apps on my home menu, but when i remove sonly select, there is not option to see iplayer. I cannot find it in the store, so I have to enable sony selecet to see it.
Does anyone have any solutions to move it to app list?
LightFoot
Specialist
Hi @Kicking_up_Dust
Not a solution I know but you can always add the Sony Select App to your Favourite Apps so the Players are available from your Apps.
