Bbc iPlayer
profile.country.IE.title
Jetdriver
Bbc iPlayer
No option to download iPlayer - I’m in Ireland.  Any suggestions how I can get this on my Sony tv (KD-43XG8096) would be much appreciated.
LightFoot
Specialist
Hi @Jetdriver  BBC iPlayer is not available in Ireland. UK only with a valid U.K. television licence.
Tonycv51
The catch up apps are pre installed in Sony Select.  If they're not showing as the Tv system is set to Ireland then you can sideload the app from a github - search for Hoshsadiq.  You'll need a VPN to access iplayer outside of the uk
