Bravia 2017 9005 android update
Morgs23
When is the new android TV update going to happen as I've read that the Americans are getting there similar TV's update now
pointy101
I have a XE9005
Sony apparently just released the list of models that are going to get the new Google TV interface ( I have it on my Chromecast with Google TV)
Does anyone know if the XE9005 will get that's update
7 REPLIES 7
Joe_Dohn
Specialist
What TV model and software version are you referring to here?
Morgs23
It's similar to the new Google TV Chromecast
Joe_Dohn
Specialist
You can find the model number of the TV on a small sticker on the back or on the box if you still have it.
Morgs23
Kd 55xe9005
Morgs23
Kd 55ex9005 currently on android 9 to android 10
pointy101
I have a XE9005
Pentium_Gladio
Specialist
What's the current software for your TV model? You can find it by pressing help and selecting system information.
Regards,
Gladio
