Can't enter password
Fizzyjelly
Using screen keyboard, I enter username but every button I tap to get to password acts as enter. Then I get invalid password. How can I get to the password line.
11 REPLIES 11
Pascale_F
Moderator
Hi Fizzyjelly,
Welcome to the community. Which product is this regarding?
Thanks,
Pascale
Fizzyjelly
KD49XF9005BU
Pascale_F
Moderator
Hi Fizzyjelly,
I'll just see if I can find anything out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Fizzyjelly,
I wonder if you have a Wireless keyboard or any USB devices connected to the TV? If you do, try unplugging them, restarting the TV and trying again.
If the issue remains, try a factory reset.
Does this only happen with the WiFi password screen? What about when you search Google or Youtube?
Win_88
Fizzyjelly
Internet on the TV
Joe_Dohn
Specialist
Have you tried pressing return after you're done with the username to then go down using the arrows and enter the password?
Fizzyjelly
Yes I've tried everything
Win_88
Specialist
Hi Fizzy,
Does that include updating the TV and resetting to factory settings?
Win_88
Fizzyjelly
I don't really want to go to factory settings. I think I'm resigned to the
fact that this expensive TV can't get internet.
