Can we get higher Home\App screen resolution?
newbix
When trying to use a app that works on my phone(side loaded) it's about half the size it should be.
Is there any way\app that will make the resolution better for side loaded apps?
Oh I have a ZD9
rooobb
So you are using an app that doesn't support android tv and surprised it doesn't work as expected ?!?
Only suggestion I can give to you is try using tablet version of apps rather than smartphone ones cause they are designed to work in landscape mode.
newbix
The same app works on my Tablet(2K\1080p screen)and S8 phone fine.
And if I turn the phone\tablet aroung it changes. I've used a app to change the screen rotation.
But it only shows half of the app. I was just hoping that we could go to 2\4K like most tablets and phones.
