Casting issue from Facebook to Android TV
MARKJW
hi,when trying to cast a music video to TV from FB on iphone, I only get the sound and no video. Background is a blue screen and the narrative 'track unknown' appears on the screen.Have tried the all the recommended fixes but still same. It has been working when casting from YouTube however, albeit I do need to connect tv manually to wifi each time(should be automatic?)When attempting to cast I can only see airplay and bluetooth options under which the SKYQ mini box is an option. Think Im correct in saying the actual tv model should need to appear and be selected in order to cast properly ? Model is KD-65AG8.
Any advice appreciated.
Mark.
rooobb
You should refer to Facebook help site in order to check how to view your videos. Your TV is equivalent to a chromecast device (not being compatible with airplay)
