Clearing ethernet IP address
daveP_uk
I've just noticed my Tv is not connecting via ethernet cable.
Connection via wifi is fine.
It's set to DHCP but has an ip address also (not reserved)
How can I clear the ip address so that DHCP can do its job.
Router is not finding the TV at all, as the rouge ip address is completely different to router DHCP range.
Any help much appreciated
2 ACCEPTED SOLUTIONS
Hi there,
Have you tried a factory reset?
Best wishes,
M
daveP_uk
Seems to have resolved itself now, no reset required.
Hi there,
Best wishes,
M
daveP_uk
