Connecting HDD to Sony XE90 TV via router
profile.country.RO.title
danny_c_19
Hello,
I have a XE90 sony tv and also an Asus RT-AC87u router. Do you know if it possible to connect a external HDD to the router (USB 3.0 Port) and access the content through the TV ? (movies, photos, etc. )
12 REPLIES 12
nohackmove
If I am going to play a movie with a subtitle in SRT file format, on android devices I mostly use MX Player.  If it has same name it runs automatically.. Also this play has a feature to search specific subtitle web sources for alternative subtitles.
You should give it a try.
Tags (1)
danny_c_19
Thanks for the hint, I will also try this. At the moment I am using Kodi to access the media from my HDD and it can also read the srt files.
Also, has anyone expericend performance problems with the SONY TV player when playing big size 4K Movies from the HDD ? I have the same problems with VLC Player, but not with KODI.
Thanks,
Daniel
danny_c_19
When I use Kodi through SAMBA I am experiencing performance problems with big 4k movies. But when I use Kodi and access the data through the Media Server everything works smooth.
