Do I need antivirus on my TV?
Budhi108
hello,
Do you have some antivirus software on yours TVs? Do I need one?
I not use browser at all on TV set, just stream Youtube videos and some streams trough Kodi.
TNX
 ps. maybe you can recommend some app for clear cash and memory on tv.
in my DX8077 allways 75% memory in use. Is this ok? I check trough Kodi system informations.
xx4L0Mxx
For what you are doing you do not need anti-virus on your TV. In fact, most anti-virus apps on Android are a total waste of time and will just bog down your system. Virus exploits in Android are normally achieved in ways that anti-virus couldn't stop anyway.
In regard to ram usage, Android isn't like Windows. High ram usage in Android is generally a good thing.
xx4L0Mxx
Budhi108
tnx....
