Freeview and freesat
spear47
I have the sony A9 48 inch tv. I currently use it for freeview with a USB drive for recording. My question is: as it also has a tuner for freesat, can both services be tuned in or is either one or the other?
Elodin
Moderator
Hey, you can use both of them at the same time bearing in mind that you need to disable youview. I hope this helps
5 REPLIES 5
royabrown2
Hero
@spear47
If it’s anything like my Samsung JS9000, then you can tune both in, and each will hold its tuning, but you can only select one or the other to watch at one time.
Can’t speak for recording, as I use a proper PVR for that 😛
Elodin
Moderator
spear47
spear47
Elodin
Moderator
Hey, you're always welcome. We are here trying to assist each other.
