HALauncher stops working after reboot
mameha1977
I installed HALauncher to quickly access the sideloaded apps that do not support leanback launcher.
After initial install, it worked great.
After rebooting the TV, it no longer works.  If I click the HALauncher icon it starts to open then falls back to menu screen.  Sideload Launcher works OK but it is slow and my favourite app starts with X so appears right at the bottom of the list!
Does anyone else have this problem or can suggest alternative sideload launcher?
Tags (2)
Hi there
If HALauncher is still not working, try removing it and re-installing.  Alternatively, try TV Sideload Launcher
https://play.google.com/store/apps/details?id=eu.chainfire.tv.sideloadlauncher
