How manually select all cast input/channel??
Jezzer25
Sony android TV, I can use the all cast function fine, however how do I manually select the input of channel that it runs on??  The problem is if I accidentally change channel or touch the remote I lose what I was casting, and the only way to get back to it is to start the whole process off again??  Hope that makes sense??
Hi there
Unfortunately you cannot as far as im aware.  Changing inputs shuts down the network connection completely.
Jezzer25
This is a major short coming as with my other chromecasts u can just select the relevant hdmi input... Is such a pain, because if u change channel even by mistake u have to restart the app and send it again to the TV
