HT-ZF9 Soundbar wall mounting
stevie1965
Can anyone tell me what gap there is from the rear of this soundbar to the wall when mounted using the included brackets?
Just wondering how much clearance there will be for the HDMI cable from my Sony Bravia TV to the connectors on the rear of the soundbar.
Mick_D
Moderator
Hi Stevie
The instruction manual (p92) shows a reasonable gap is left behind the unit and Sony do recommend it stands off the wall a little to avoid overheating.
As you can see, you should be able to slightly adjust the gap and I would expect all but very thick cables could be run behind.
Hope that's the info you needed.
Mick
stevie1965
Thanks Mick
Appreciate the response.
Page 92 of the instructions you linked to is the back page with no pictures but I take on board what you say about the gap at the rear.
Regards
Steve
