iPlayer missing after Marshmallow upgrade
bar-ad
Hi
Finally got the Marshmallow upgrade for my kd-49x8307c a few days ago 2hich seems to have solved some issues with the TVs WiFi.
However, since the upgrade BBC iPlayer has disappeared - can anyone help resolve this?
(Tried rebooting, but this did not seem to help)
bar-ad
Thanl you for the quick reply.
I've checked using the link you've provided and my ip address is showing (as expected) that I am in the UK. So not sure why the TV loaded without it.
Restart did not reso;ve the issue and I do not want to try a factory reset as when I did it in the past, the TV came up withput the Amazon Video app. I guess updates are flakey on the Sony Androidmversion.
Searching for more details lead me to a  website saying that clearing data of the Sony Select and Sony Shelf apps and then rebooting should work - and it did! I now have BBC iPlayer back again.
So if anyone else comes across thisnissue in the future, you can try the above and prevent a painful factory reset experience
Hi there
Try this:
  1. Turn TV completely OFF
  2. Reboot your router
  3. Once router has been rebooted, turn the TV back on again and test.
BBC iPlayer will only work if you have a UK based IP address, to check goto : https://www.iplocation.net/
All else fails try a factory reset, see instructions HERE.
bar-ad
