KD-65X8509C bought within the last week
I have the TV's IR Blaster setup to control a BSkyB Sky+HD box, and most controls work great. However, the UP/DOWN/LEFT/RIGHT navigation buttons work, but always sends 3 occurrences of UP, DOWN, LEFT, or RIGHT instead of just one occurrence.
So, for example, when navigating the Sky+HD box list of recordings, pressing down skips down 3 recordings, making it impossible to select the recordings in-between.
Is there some way to update the IR blaster database to correctly only send 1 occurrence of LEFT, RIGHT, UP, or DOWN when that button is pressed? Or is there any other solution to this problem, that will make the UP/DOWN/LEFT/RIGHT buttons behave correctly?
Solved! Go to Solution.
Hi all
Are you saying that after a factory reset that this issue is finally fixed now?
I am away from home at present but will try a factory reset when I get back. Thanks for the help.
Confirm - now fixed after a factory reset. Thanks again for the help.
Thanks guys.
I have this problem now . Have done factory reset and to says up to date.
I too am having this problem. KD-49XE9005. Factory reset hasn't helped
Hi. Wondering if you can help. Just bought a KD8005 and I am unable to access the Sky Planner/ Recorded programmes from the IR blaster.
Any suggestions would be welcome
