KD-49X8005C keeps randomly rebooting
MrBealzebub
Hi. Since coming back from my holiday last week my TV keeps randomly rebooting. Prior to going away it was working fine. Also, while away all of my programs failed to record on the attached hard-drive stating that the first programme had been interrupted due to the power going off. Was there an update of some kind released last week as it seems really odd that things appeared to start going wrong when I wasn't even about to use the TV?
Mick_D
Moderator
Hi @MrBealzebub, welcome to the Community.
Would it be possible to establish which Android version you are running? Plus any firmware updates you have carried out in the recent past, including the current one. It would help if you can supply as much of this sort of information as possible.
For your reference, the most recent updates can be found here.
Mick
