KD-49X8305C Powering Down Issue
dan_88
Hey Everyone!
Got a random issue I've just started noticing.... The past couple of nights, as I come to turn off the TV, I turn it off on the remote, the TV switches off, and it switches off the soundbar (HT-RT5) and about 2 or 3 seconds later, the TV is back on and taking the soundbar out of standby, just as if I've just turned the thing on...?!?
Has anyone else experienced this? Any clues how to fix? If its a known bug, does anyone know if the the impending update fixes it?
So many questions!
Cheers in advance!
Dan
Hi there
Sorry that no one has responded.  Curious to know if you managed to solve the problem?
dan_88
Hi, Sorry I didnt reply to your reply - I've not logged in since May!
Yes it did get solved once I updated, but it has started randomly powering up randomly now! Oh well! I've seen a few people mention this on here - so I've switched off my BT YouView box as I hardly use it anyway and will see how it goes!
I've logged in to report another issue but will start another thread :slight_smile:
