KD-49X8305C Software update crash 64%
grayhm63
Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
135 REPLIES 135
mah_01
hi @Anonymous, thanks for your quick response, I will try the fix later tonight.
Cool - let me know how you get on.
grayhm63
It worked for me, so all the best.
Cccckj
Can you also please send me the fix? I've tried a number of USB keys and when plugged into usb1 I briefly get the loading screen then it just restarts. The other ports reset the tv immediately. Thanks
@Cccckj - can you please reply back with the model number of your tv?
Cccckj
Spoiler
I also have the KD-49X8305​C, thanks.
@Cccckj - ive sent you a private message, please let me know how you get on.
Cccckj
Many thanks it worked!
mah_01
It worked for me, many thanks
arun_moon2004
@Anonymous Even I have the same problem.
Model: KD 55X8500C
Appreciate if you would please help to resolve.
Many thanks.
Tags (1)
