My KD-55AF8 has developed a line across the screen about 10 centimetres from the top. The picture above the line is clear but below a series of feinter lines down to the bottom of the screen. There is also a shadow about 10 centimetres wide from top to bottom on the right side of the screen. Has anyone had this issue?
Regards vancouver07
Can you please run a panel refresh from the menu and check if this fixes the issue.
https://helpguide.sony.net/tv/faep1/v1/en/07-01_05.html
If not, please get in touch with Sony Support.
Peter
Hi, Thanks for the reply. I have tried refreshing the screen but it's still the same so I have contacted Sony support a they are sending an engineer.
Regards vancouver07
